f_d,
The GPIB read VI returns whatever data was read from your instrument. The format of the returned data depends on the commands that were issued. Some instruments can send information as either binary / ascii. It could be that the command that you're sending is instructing the HP 16500b to respond in binary. If, however, the response is in ascii, then wiring the "data" output of the GPIB read to a text indicator will display legible information. Also, if you are already using a text indicator, make sure that it's in "Normal Display" mode rather than "Hex" or "\Codes."
There is more information available about this VI in LabVIEW help. Also, you can refer to the HP 16500b manual for a listing of valid commands.
Have you considered upgrading to
EF="http://www.ni.com/labview">LabVIEW 7.0? It includes the
"Instrument I/O Assistant" that makes reading / parsing instrument data VERY easy.
Alan
Applications Engineering
