agilent 548XX diver
I am using the Agilent driver I downloaded from NI. When using the Acquire VI, my scope display disappears even though I have set the display after measure to TRUE. Anybody else have this happen?
(3,380 Views)
Are you using the IVI driver or the Plug in Play? When does the display disappear, and by disappear do you mean the graph clears? Have you tried setting display measure to False?
Shawn B.
Use NI products on Linux? Come join the NI Linux Users Community
(3,380 Views)
I am using PnP drivers. What happens is I can acquire the waveform on a Waveform graph within the VI, however the scope display disappears. This is the normal behavior of the scope after isuing a :Dig command, however there is an input on the VI to restore the display after digitizing (as long as it is set to true). This does not restore the display however. The VI that is being used is the hp548XX ActnMeasurement Aquire 2.vi from NI.
(3,381 Views)
hi,
could you post that vi?
(3,291 Views)
You can download the PnP driver which includes this VI from ni.com/idnet.
Shawn B.
(3,276 Views)
