07-27-2011 09:41 AM
For some unknown reason the LabView MAX cannot connect to my YOKOGAWA DX2020 over the ethernet. The ethernet is communication is present because I can ping the YOKOGAWA and it responds correctly. Then I used the LabView Measurement and Device Explorer (MAX) Device Interfaces/Create New/ VISA TCP/IP. I entered the fixed IP address for the YOKOGAWA and then the validate button said error "Insufficient location information or the device or resource is not present in the system."
How do I correctly setup the YOKOGAWA DX2020 to communicate over ethernet with LabView 2010?
07-27-2011 09:52 AM
Do you know for a fact that it's VXI-11 compliant? Did you try the RAW option?
07-27-2011 02:07 PM
The YOKOGAWA DX2020 does not appear to be VXI-11/LXI. They were not automatically found on the local subnet. I also attempted the RAW IP address. I entered the exact same as setup up on the YOKOGAWA DX2020. I made sure the USE ethernet was turned on also.
07-28-2011 01:01 PM
I found the solution. The port number for the YOKOGAWA DX2000 series is 34260. The DNS IP address was added to the Internet Protocol (TCP/IP) connection. This must be the same fixed IP address that you created in the YOKOGAWA Ethernet setup menu. Then start the LabView Measurement and Automation Explorer (MAX). Create a new device interface using the VISA TCP/IP. Use the Manual Entry of Raw Socket resource. Enter the IP of the YOKOGAWA along with the port number 34260. The LabView 2010 MAX is then able to find the chart recorder Ethernet port after clicking the validate button. Then create any alias name for your YOKOGAWA. Then start a vi such as the Yokogawa DX200 Acquire Continuous Multiple Measurement Data Example.vi. The alias will be in the VISA Resource Name pull-down list. Then click the run button.
Good Luck....
07-14-2016 12:44 PM
How did you find the port number to your YOKOGAWA? I have a PNA that is VXI-11 compliant and I am having the same problem, NI-MAX cannot see it, although, explorer can access my PNA.
07-13-2017 06:54 AM
it was a life saver. really appreciate your inputs.
