With the GPIB Bus , Every 10 seconds I must change the input Voltage of the Power Supply with a loop. But How...
Dear Friends,
for my very basic test case ( I have a resistor which takes its input voltage from Agilent E3631 Power Supply and an Oscilloscope is connected to the resistance to see how the voltage changes.
I can change the output manually and everything works fine.
I wrote a program which gives the first input value to the Power Supply, but I can`t manage to increase the input by 0.5 Volt steps by using a loop.
For instance, I begin with 0 Volt , and want to test till 25 Volt by 1 Volt steps.
So the question is: How should I use a loop to increas the output from 0 Volt to 25 Volt? if I use I/O Assistant inside of the loop , each time he takes the first value and no icrease of the voltage happens( or just one , and it turns back to the first value ) 😞
PLEASE HELP ME !°!
With Best Regards
Message Edited by Support on 11-13-2007 12:59 PM
(2,801 Views)
i think you have your output-signal not in the loop. So you get only the start-value (0 Volt) and the end-value (25 Volt).
Here you have an example. You have to change the hardware-settings, but you can use the loop.
Regards
Markus Weigl
NI
(2,785 Views)
I am using the version 7.0 , could you please convert your vi to ver. 7.0 .
thanks
(2,782 Views)
here is the version for 7.0:
(2,776 Views)
