04-06-2014 08:19 AM
I am trying to use a Hokuyo URG -04LX-UG01 LiDAR on a myRIO. I read that i should try to communicate with the device in MAX but then i got the error shown in the picture. I've tried this https://decibel.ni.com/content/docs/DOC-35698 but it wont work, and read this http://forums.ni.com/t5/LabVIEW/myRIO-VISA-Error-1073807192/td-p/2747056 but since i can see the usb in MAX i don't think i have the same problem. Can someone help me understand?
BR
Anna
04-06-2014 10:10 AM
Okey, progress.
But still I don't understand why it doesn't work correctly.
04-06-2014 10:19 AM
04-10-2014 09:34 AM
Hi Ragge,
Are you sure no other running process is trying to access the same device (COM port) as the lidar?
Could you please try resetting the MAX database: http://digital.ni.com/public.nsf/allkb/2C7480E856987FFF862573AE005AB0D9
If you plug the LiDAR into your computer instead, is it then accessible in MAX?
