Hello ScrapIron �
When exactly do the port numbers change? Is it when you unplug the USB adapter and plug it back in? If so, it could be that your OS has not released the previous port numbers and therefore assigns higher numbers.
This could also be an issue with the driver of the third party (keyspan) device. Please make sure you have the most updated version of the keyspan driver (version 2.1).
A simple workaround to this problem may be to use the VISA Find Resources VI to programmatically find the instruments.
For information on how a USB-to-Serial Adapter with LabVIEW assigns port numbers on a Macintosh, see this
KnowledgeBase.
Have a great d
ay!
Becky B.
Applications Engineer
Becky Linton
Field Engineer
Office: 734-464-2463
Cell: 248-709-2822
Email: becky.linton@ni.com
