Which pins are the RTSI lines on the 100 pin IMAQ board connector?
I want to trigger my Kodak KLI-1424 CCD camera board using my IMAQ PCI-1424 board. The problem is that the technicians and my work say that I need some kind of RTSI line that is connected from the IMAQ board to the camera. We have the 100 pin connector comming out of the IMAQ board and only certain pins are connected to the CCD board. I would like to know which pins on the output from the IMAQ board are being used to handshake the trigger lines to the board.
Brian
(2,891 Views)
Brian - It sounds like you are wondering which lines are used for triggering on the 1424. This does not use RTSI - RTSI is the separate connector on the side of the PCI board that allows you to directly connect multiple boards. I believe the trigger lines you are looking for are pins 95-98 on the 100 pin connector. These external trigger lines are explained on the page following the pinout in the user manual.
Hope this helps -
Julie S
(2,890 Views)
