Where can I find NationalInstruments.NI4882.dll?
I am using a GPIB adapter to connect to a machine that I want to control using VB .NET. I've installed the examples for .NET 4.5, and one example imports NationalInstruments.NI4882. I can't seem to find a dll by this name on the "NI-488.2 for Windows Version 14.0" CD. Where would this file be located on the CD, or where can I download it directly, or is there a dll with a different name I should be referencing?
(8,587 Views)
Accepted by topic author jpreynolds
The dll should have been installed when you installed the 488.2 drivers.
GCentral
(8,585 Views)
Is there any difference between what is on the CD I received and what is available at http://www.ni.com/download/ni-488.2-14.0/4802/en/ ? The CD I have is "NI-488.2 for Windows and NI LabVIEW Real-Time Version 14.0". From the CD installation, I've searched the Public Documents -> National Instruments folder, as well as the Program Files -> National Instruments folder, but I haven't found anything with ni4882.dll. Do you know the location where the DLL should have been installed? I found a NationalInstruments.Common.dll, would I reference this or do I need to find the specific 488.2 dll?
(8,571 Views)
Nevermind, I believe I found it in the MeasurementStudio folder, thanks!
(8,562 Views)
