What is ni579x?
In our lab we use ni9146 for realtime io (rio).
In MAX and in the project explorer this device shows as NI-NI9146-01893549
without a warning sign.
Connecting this HW to another computer (which shall become the development computer)
and opening the project on this machine the project explorer shows a warning sign next to NI-NI9146-01893549.
Could you help me finding out the source of the problem?
My guess is that some driver isn't correctly installed. May this be related to ni579x as
the tools->INSTRUMENTS->drivers menu on the lab computer shows
- Agilent 34401 and
- NI579x
whereas the same on the desired develop computer shows only
- Agilent 34401?
This is what NIMax shows on the lab computer where ni9146 works well :
 This is what NIMax shows on the desired development computer:
Thank you!
(4,980 Views)
Hello Labuser,
Setup Guide for Ethernet RIO Expansion Chassis
http://www.ni.com/white-paper/11703/en/
3. Required Software for the NI 9146
  1. LabVIEW 2011 or later
  2. LabVIEW 2011 FPGA Module1 or later
  3. NI-RIO 4.0 or later
Note: Software should be installed in the order listed
1LabVIEW FPGA is only necessary if you plan to write your own FPGA program for the FPGA target in the NI 9146. Use of the Scan Mode Interface is possible without the LabVIEW FPGA Module.
Stefan
(4,939 Views)
When you click the warning, what does it say?  That's probably a good starting point.
(4,876 Views)
