04-10-2015 07:00 PM - edited 04-10-2015 07:00 PM
I am trying to run the Watlow F4 Controller Driver downloaded from NI website to control an environmental chamber. I connected the GPIB port to PC using a GPIB-USB-HS cable. The GPIB to ModBUS interface board ICS 4804A is found in MAX and I am able to get queries from it with *IDN? command. When I run the Watlow VI. I got Error -1073807331 (0xBFFF001D) The Specified attribute is not defined or supported by the referenced resource. I am not sure what I am missing. Please see attached picture for details. Any suggestions are greatly appreciated.
Many many thanks
Fliu
04-10-2015 08:00 PM
Depends on what that VI is trying to do.
Only you would know since you have the VI.
04-10-2015 08:21 PM
04-10-2015 08:25 PM
04-13-2015 05:23 AM
Thank you for your reply. I run step by step. The error happened during initialization. I got the following :
Property Node (arg 2) in Watlow F4.lvlib:Initialize.vi->Watlow F4 Profile.vi
"<ERR>WLF4 Initialize The ID Query Failed. This may mean that you selected the wrong instrument or your instrument did not respond. You may also be using a model that is not officially support by this driver. If you are sure that you have selected the correct instrument and it is responding, try disabling the ID Query"
I am using a watlow F4 controller and I was able to get query through *IDN? Please see attached pictures. Any suggestions are greatly apprecited
Fliu
04-13-2015 07:14 AM
