02-22-2012 08:44 AM
I try to connect a usb device to lavview through the VISA tools, the device generate data in th form below, when I try the connection I got "time out expired" I tried to increas the time but it did not work. Any suggestions?
I attached the VI also
| 10:40:42,0:00:01,-0.87,0.000000,0.000000,0,0010000 |
02-22-2012 12:07 PM
Have you tested it with a terminal emulation program such as Hyperterminal/Procomm/etc.? Are you sure you do not have to send a command to the instrument to initiate a measurement?
Why haven't you provided the make and model of the instrument? That's pretty important information. Can you provide the programming manual or a link to it?
02-23-2012 03:15 AM
The device has its own software for getting data, but I need to connect it to Labview because I have more than one device and I want to make them all in Labview.
I tried hyperterminal but nothing appeared. I do not think there are some initialization for the device.
I attached the manual here.
02-23-2012 09:46 AM
I'm not sure why you attached that document. Itr does not contain anything on the details of the serial communication protocol. Without that, you would have to use a serial port sniffer such as portmon and use the vendor's software to attempt to capture the actual details.
02-27-2012 11:06 PM
How you should program differs depending on the protocol that the device is using.
Virtual COMM port ?
USBTMC ?
any custom protocol?
Makoto
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
