05-23-2017 10:49 PM - edited 05-23-2017 10:49 PM
I have a setup consisting in a PC running Win7 x64, LabVIEW 2014 x64, a RS232 instrument, and NI-VISA for the communication. It used to work well but for some reasons I recently got the following error message (-1073807202) when trying to open the COM port:
LabVIEW: (Hex 0xBFFF009E) VISA or a code library required by VISA could not be located or loaded. This is usually due to a required driver not being installed on the system.
I have tried to completely uninstall NI-VISA and install the latest version (17.0) including support for 32b and 64b. However, I still get the same error. When running LabVIEW 2014 x86, no error, it's working. Same results with MAX.
When I install NI-VISA, the default location is C:\Program File (x86)\National Instruments. I have tried to install it in C:\Program Files\National Instruments instead but the installer refuses because of "incompatible product installed" in the directory.
I have check the content of Windows\System32 and there are visa32.dll, visa64.dll, visaConfMgr.dll, visaUtilities.dll
In Windows\SysWOW64: VISA_Shared_CleanupUtility.exe, visa32.dll, visaConfMgr.dll.
Any suggestion would be welcome.
Thanks.
Pierre
05-25-2017 12:03 PM
You may be missing a service pack
05-30-2017 09:15 AM
Have you let VISA install itself to the default directory before you had this error?
05-30-2017 09:20 AM
Actually, I do not have the choice: it has to be in the default directory (C:\Program Files (x86)\National)
05-30-2017 09:35 AM
The latest several versions of NI VISA use SHA-2 signing. Unless you have applied the Microsoft patch I linked to earlier (Which adds SHA-2 signing) it will not work correctly.
05-30-2017 02:35 PM
Finally, I managed to make it work. Instead of trying to install the latest version of VISA, I got back to the original LabVIEW 2014 Driver DVD and installed VISA from this DVD. Now, both x86 and x64 versions are working well.
I did not have the chance to try the service pack you propose. I will keep it in mind for the next time.
Thanks.
