VISA file write works on 32 bit WIN 7 but not 64 bit
I don't have Labview installed on the 64 bit machine. It's on my 32 bit machine
Message 11 of 33
(2,595 Views)
Then why are you saying it doesn't work on the 64-bit pc? Did you do a build? You can still do a trace.
Message 12 of 33
(2,589 Views)
I made an installer and put an executable on the 64 bit machine. You are saying I can run a trace on an executable, not just source code??
Message 13 of 33
(2,585 Views)
Mike,
You can download NI I/O Trace from the following link and install it on your 64-bit machine.
http://www.ni.com/download/ni-io-trace-3.1.1/4285/en/
Rob B
FlexRIO Product Manager
Message 14 of 33
(2,583 Views)
The I/O trace monitors VISA calls and it does not know or care if the calls come from an exe or a development system.
Message 15 of 33
(2,579 Views)
I have captured the traces for each computer and have tried to attach them but the blog errors out when I try to post the message
Message 16 of 33
(2,531 Views)
I cannot attach the capture files to this post in either *.nitrace or *.txt format
Message 17 of 33
(2,517 Views)
Here are the capture files in text format. MyPC is the system that works and the Chenbro is the system that does not
Message 18 of 33
(2,490 Views)
I just need some pointers on how to interpret these messages
Message 19 of 33
(2,489 Views)
Are both PCs using the exact same USB-serial adapter?
Message 20 of 33
(2,482 Views)
