My question is generic and does not pertain to a specific test instrument. Instead I am trying to find out if VISA will allow me to keep track of a VISA instruments test settings (i.e. status).
For example, I am developing a TestStand sequence where each test step accesses the same VISA test equipment. Each test step may or may not set a different setting on the test equipment. Again as an example, one piece of test equipment is a VISA (GPIB) controller DC power supply that these test steps will access to perhaps set a different voltage setting. Test Step 1 will set the power supply output to 5 VDC, Test Step 2 will set the power supply output voltage to 4.5 VDC, and Test Step 3 will keep the power supply voltage set to 4.5 VDC.
Here's my question, is there a feature in the VISA driver that will keep track of the power supply's voltage setting so that when Test Step 3 is executed, I can use this feature in the VISA driver to see that the current setting on the power supply is what the test requires and thus eliminate the need to execute a write command to the power supply to set it's voltage output setting?
To put my question in simpler terms, does VISA have a way of keeping track of an instruments status (i.e. test settings)?
Thanks in advance for your time and response.
Thanx,
Jim
