10-09-2014 07:03 PM
Hi ,
I'm trying to connect my PC to the Ixia Traffic Generator using the NI MAX and using ethernet, got the message:
IP address of device: 2.10.2.7 and socket of 23
Error opening resource:
TCPIP0::2.10.2.7::23::SOCKET
VISA: ( Hex 0xBFFF0011) Insufficient location information or the device or the resource is not present in the system.
With the same above configuration, I have no problem connecting the device.
What is the problem? Please help.
Phong
10-10-2014 05:08 PM
Hi Phong,
What do you mean that you have no problem connecting to the device? Can you properly communicate with it in non-NI software?
Is this error in LabVIEW? Can you communicate with the device using MAX Test Panels?
10-10-2014 05:31 PM
Hi Daniel,
Sorry to confuse you
I meant I had no problem connnecting the device on different PC using the same settings.
I have problem using MAX Test Panels. I use this MAX to communicate with the device first before using LabView.
I'm not sure I missed any of the traffic generator functions.
Phong
10-13-2014 02:18 PM
Can you successfully ping the device through the terminal, or communicate with it through any non-NI software right now?
10-13-2014 04:49 PM
No Daniel,
I'm even using Agilent IO Expert and it is still not working.
Phong
10-15-2014 09:30 AM
Is the device on a switch or router? are you using a serial to ethernet converter? Have you used other devices on the port before?
12-03-2014 03:47 PM
Hi Daniel,
Can you with this?
