02-13-2014 08:25 AM
I am new to LabView 2013.
I made hardware for collecting data from deivce using serial port.
My requirements are:
I want to make real time graph of incoming data from hardware through serial port in pc.
Now experts please help what are necessary things are required to make real time graph of incoming data coming via serial port to pc in Labview 2013.
What are the components are required in LabView to do such project.?????
Please provide me complete information because I am new in LabView 2013
Waiting for your response.
02-13-2014 09:09 AM
02-13-2014 09:27 AM
The harware made by myself which is 8051 controller that convert the number of bits that run seven segment display to ASCI which is compatible as our compter data.
Now please tell me after connection to labview, in order to make real time graph of incoming data from instrument what are the main componets require to make real time graph of incoming data in labview
02-13-2014 09:46 AM
02-13-2014 10:02 AM
The hardware is in progress stage and not complete yet now.
Of course data format is ASCII obviously Can you explan following thing said by you
How many bytes are being sent? Is there a termination character being sent? Is the serial port listed in MAX?
02-13-2014 10:35 AM
02-13-2014 11:07 AM
okay connection is done with pc with serial to usb converter.
Now you have to tell me next procedure that what are required in Labview to analyze and make a real time graph of incoming data in LabView.???
From where I will start in Labview to make a real time graph in the end output. What is required in starting if I use visa for read only data.
02-13-2014 11:17 AM
