09-26-2006 03:55 AM
Hello
I'm trying to communicate with a device which have to be tested with my application. So I send it a command to initiate the device to send me back some values. This values are sended continously with a baud rate of 57600.
I create a VI to test this communication but I always get the error:
VISA: (Hex 0xBFFF003E) Could not perform operation because of I/O error
I have googled for this thread, but all the described solutions didn't solve my problem (ex. Set Buffer Size to 48, Various Byte Count Values for the VISA Read function, etc.).
Note: the VI works properly in the LabView 6.1! I have tested. I also tried to receive the Data with a Termial programm (works fine). But another COM Port (on an USB Serial converter) shows me the same Error.
I just updated to Visa 3.4.1, but no success
LabView 8.0.1
09-26-2006 07:05 AM
09-26-2006 10:07 AM
09-26-2006 04:29 PM
07-07-2015 04:03 AM - edited 07-07-2015 04:07 AM
Hi, I have set VISA Set I/O Buffer Size(48,4096) before write and read function, but the problem still exists, can you give me some advice?
Thank you very much!
04-26-2019 03:02 AM
Hello! Have you solved the problem?
I meet this problem now,could you give me some advice,thank you very much!
