10-28-2014 01:04 PM
Below is an ttachment of the screen when I try a Query to the INstron 4400. Also attached is the NAIO trace.
Read Operation
Error
VISA: Hex(0xBFFF0015) Timeout expired before operation completed.
When I turn on the Instron Software to run the Instron (with IEEE enabled), it says that the program is unable to establish communication with the frame.
10-28-2014 01:15 PM
Sounds like you have a problem with your instrument. Maybe you should go call up their support.
But some general ideas:
Is the GPIB address in the instrument actually set to 4?
Is the GPIB enabled on the instrument?
Are you sure the instrument is connected via a GPIB cable?
10-28-2014 01:25 PM
Yes, checked in the ADMIN of Blue Hill
Yes, when "IEEE" is enabled, the machine communicates through the 488.2 card.
Yes, National Instruments 763507B-04, Type X2 GPIB.
I'll try their support again.
10-28-2014 01:36 PM
10-28-2014 01:53 PM
Sorry for the confusion. We recently moved the machine and when we reconnected the machine to the computer, we lost the ability to talk back and forth. I have been trying to troubleshoot and using the VISA test panel I can get a write command to say:
1. Write operation (*IDN?\n)
Return count: 6 bytes
But when It ry and read, it throws the error.
I don't know if this means that the write command is getting through or not.
I
10-28-2014 02:05 PM
10-28-2014 02:13 PM
Sorry, I am not getting that deep, the VISA program makes the command. I beleive that "IDN?" is the identification query. Attached please find the screen that I use to try and communicate with the instron through VISA in NI MAX.
10-28-2014 02:16 PM
