12-12-2011 02:19 PM
When I tried to find my USB-GPIB resource through the VISA Find Resource node, I can't find it. The resource is clearly shown when I drop down a visa resource constant and in MAX. See attached picture. I have tried all the options for the VISA Find Resource node already. The resource is supposed to have an address of 3. Thanks!
12-12-2011 02:58 PM
below is an inputstring that defines to search only in gpib.
You can see a complete list in the help of the function Find VISA Resource.
Did you try this input string?
And did you get an error and what did it tell you?
GPIB?*INSTR
Matches GPIB0::2::INSTR, GPIB1::1::1::INSTR, and GPIB-VXI1::8::INSTR.
12-12-2011 03:05 PM
I tried ?*. Shouldn't that gives me all resources? I tried different serach things, and there were not error. However, the GPIB that I want didn't appear.
I am expecting GPIB0::3::INSTR, but I only got GPIB1::INTFC from the Find VISA Resources noe. I am able to get the correct GPIB resources string through a regular resource constant and MAX. See picture from my first post. Thanks!
12-12-2011 03:08 PM
12-12-2011 03:28 PM
I will try this tomorrow when I have GPIB connection. I will let you know what happen.
12-13-2011 12:48 PM
I tired it. It doesn't work. It seems like the problem comes from the fine visa resource node. It fails to find all the resources, even MAX sees the resources.
12-13-2011 01:32 PM
See attached for the problem. I can find my resource through a resource name control, but I can't find it through the Find VISA Resource node. Why is that?
12-21-2011 03:01 PM
Hello jyang7221,
I tried to reproduce the issue that you are experiencing with no success, it works fine for me. I would suggest you to run a repair or reinstall of NI-VISA as it seems to be a problem with the VISA Find Resource VI.
