Using local variables to "clean up" diagram
I have attached a photo with red circles indicating my use of local variables to "clean up" a block diagram. Would I run into any issues doing this? Can I leave this task and error unwired?
-Sarah
Message 1 of 8
(5,262 Views)
The photo may have not attached:
Message 2 of 8
(5,260 Views)
No image but using locals as a way to clean up messy programming is NOT desirable. You are just making things worse. Numerous, numerous threads on why you should minimize/eliminate the use of locals.
Have you taken any of the free tutorials?
Message 3 of 8
(5,257 Views)
Dennis,
I have completed Core 1 + 2 but haven't done any tutorials beyond that.
I will take out the local variables and look up those threads for further explanation.
Sarah
Message 4 of 8
(5,252 Views)
I see the image now. You probably won't have any problems except possibly with the set local but the others just seem like lazy coding, sorry to say. Also, the use of the VISA Bytes at Serial Port is generally incorrect if the instrument sends a termination character.
Message 5 of 8
(5,241 Views)
Accepted by topic author sarahzig
I see some possibly really bad race conditions with your VISA Resources.  For instance, if Task Out 3 is empty (by default), it is likely that the local to read will happen before the local to write.  What this will turn into is you loosing your VISA Reference in the shift register.  Use wires.  Locals very rarely clean up your diagram.
GCentral
Message 6 of 8
(5,204 Views)
Consider putting all functions relating to the DAQmx task in a Action Engine.  Cleaner top level code.
Message 7 of 8
(5,181 Views)
Thanks for the explanation - I'll take out the local variables.
Sarah
Message 8 of 8
(5,149 Views)
