EARG (4)
Error Condition: Invalid argument to a function call.
Description: EARG results when an invalid argument is passed to a function call.
Possible Cause: The following are some examples: you call ibtmo with a value not in the range 0 through 17 (possible timeout values correspond to a table of values ranging from 0 to 17, where the default is 13, which represents a 10 second timeout); you call ibeos with meaningless bits set in the high byte of the second parameter; or you call ibpad (or ibsad) with invalid addresses.
The reason you are getting the error is because not only is your secondary address invalid, but your primary address is also invalid. Lines 14 and 16 of your attached NI-SPY capture set
the primary address (ibpad) and secondary address (ibsad) respectively. You need to make sure that you are passing the addresses properly to the subVIs using a connector. It seems like your programming when sending and receiving data (like the addresses) from your subVIs is not correct. You have to be sure to pass the data back and forth in the proper method using connectors.
A.S.
Anu Saha
Academic Product Marketing Engineer
