I followed the step you followed above for converting the CVI driver to LabVIEW VIs and I was able to convert them to LabVIEW VIs ok. Here is the LLB it created. I'm not sure how to see the error you are seeing. Could you explain how from the attached LLB below that I can see the flashing error you are referring to?
Steven B.
Applications Engineering
