03-16-2012 04:30 AM
I have the same problem while installing LabVIEW 2010 on a Windows 7 32 in a Virtual Machine with an installed LabVIEW 7:
"Nicht unterstützte Version von NI-IMAQ gefunden."
Problem is: I absolutely need all versions of LabVIEW, starting at 7, especially version 7 in order to create compatible VIs for our customers. Also I need all versions to check and correct customer VIs doing customer support. I do not want to create a VM for each existing LabVIEW version.
LabVIEW 2011 seems to install without problems. But I need LabVIEW 2010 too, because if I correct a customer VI, which is 2010 with 2011, the customer can not read the corrected VI anymore.
Is there any solution?
Thanks in advance
Stefan
03-16-2012 05:09 AM
Problem solved with extra installation.
03-16-2012 05:22 AM
Problem not solved. MAX wont show my GigE Cams.
03-16-2012 08:18 AM
The only Windows OS that supports LabVIEW 7 through LabVIEW 2011 is Windows XP. However, even if you were comfortable using Windows XP, there is no NI-IMAQ version that supports this many versions of LabVIEW. So, in summary, you need to create a series of virutal machines based on the OS / LabVIEW / IMAQ versions you are trying to support.
See links in Eric-M's previous post:
Eric-M wrote:
One thing I noticed about your programs is that you have LabVIEW 8.0 installed. LabVIEW 8.0 is not officially supported in Windows 7. Is it possible for you to remove LabVIEW 8.0 from your computer? Also, I do not believe that Visa 5.1.1 is compatibile with LabVIEW 8.0. You can find these compatibility charts in Windows Version Compatibility with LabVIEW and Compatibility between LabVIEW and NI Drivers.
03-16-2012 08:43 AM
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
