USB-8451 pull up resistor
Dear all,
I'm using the 8451 as i2c master, and for some reason (not important for this discussion) I need to use one of the 8451 pins as a 3.3V voltage source.I chose a DIO pin for the job and with Labview I managed to configure it properly to 3.3v with "push pull" driver type. My question is if there's an internal pull up resistors and if so, how could I configure it?
Or
(3,754 Views)
The USB-8451 does not have the built-in pull up resistor.  If you want to keep using the 8451, I would use the +5V output and then a 3.3V regulator to get your 3.3V.  You can then use 10k resistors for a pull ups.  Your other option is to just buy an USB-8452, which has the option to enable the I2C pull up resistors to 3.3V (or 1.2V, 1.5V, 1.8V, or 2.5V).
GCentral
(3,737 Views)
Thank you.
Are you familiar with a way to staticaly determine the sda or scl pins?
I would like to assign a logical '1' or '0' for a long period of time rather then just sending specific bytes with the labview's i2c writing example (which by the way,keep returning the msg I have attached)
Thanks again.
(3,731 Views)
