Trouble using one Keihtley 2400 to preform a current sweep to drive a laser diode and use a second to measure a voltage from a laser power meter.
I am trying to drive a laser diode with one 2400 Sourcemeter using a current sweep, while simultainiously measuring the voltage of the analog output of a Thorlabs Pm100a powermeter. I have been attempting to cobble together the triggered measurments example with the sweep and measure example, but I cant quite figure it out.
Attached is the franken-vi I have created.
Any help is greatly appreciated.
Dan R
(4,322 Views)
Are you getting any error codes when trying to run this modified VI? What are the results when running?
(4,248 Views)
Hi may have a copy of the modified vi ?
Many thanks ... Indeed I may use 2 2400 PNP bipolar measurement
(3,806 Views)
