04-05-2017 02:58 PM
I have an old application that still uses some NI-DMM resource names with "Traditional DAQ device number" syntax: DAQ::Traditional NI-DAQ device number[::INSTR]
After recently upgrading to Win10 and current versions of DAQmx, IVI, and NI-DMM, I now get an error in initialization:
Error -1074118656 occurred at niDMM Initialize.vi
Possible reason(s):
Error: (Hex 0xBFFA4000) ERROR: Device was not recognized. The device is not supported with this driver or version.)
I suspect the problem may be the use of the old syntax, but looking at the NI Digital Multimeters Help for the niDMM Initialize VI (I'm using LabVIEW), it states:
Instrument Descriptor contains the resource name of the device to initialize.
The resource name is assigned in Measurement & Automation Explorer (MAX). Refer to Related Documentation for the NI Digital Multimeters Getting Started Guide for more information about configuring and testing the DMM in MAX. Valid Syntax:
Can anyone confirm for me that this is the problem and that the documentation is wrong? Is there a document or readme somewhere that describes this change in functionality? Is this not really the problem?
Thanks!
Matt
Solved! Go to Solution.
04-07-2017 08:51 AM
Hi Matt,
Can you verify that the device is actually supported by DAQmx? Converting between Traditional DAQ to DAQmx requires a little bit more work than just upgrading software. What is the device what you are using and what was the version of DAQ you were using previously and the current version? I think the forum post you made mentioned 16.1.0 but I wanted to make sure.
Thanks!
04-07-2017 09:49 AM
The device is a PXI-4065 DMM. We have been using the device with NI-DMM and DAQmx for quite some time.
I am not converting the code from Traditional DAQ to DAQmx. I'm just using old software that uses the Traditional DAQ device syntax (DAQ::Traditional NI-DAQ device number[::INSTR]) as an input to NI-DMM VIs.
We were previously using the device with DAQmx 15.1 , IVI 15.0, and NI-DMM 15.0 on Windows 7 x64.
We are currently testing the device with DAQmx 16.0, IVI 16.0, and NI-DMM 16.0 on Windows 10 x64.
04-07-2017 09:58 AM
Hi Matt,
How does the device show up in NI MAX? Are you able to update the code such that your resource name now matches the syntax that is accepted?
04-07-2017 10:07 AM
Hi Aulia,
The device is configured with the name set to the number used as the device number.
We would prefer not to incur the cost of going through a build and test cycle.
I am trying to determine if the old style syntax (which is shown as valid in the current documentation) is the problem and that the documentation is wrong. Are you saying definitively that that is the case?
If so, I would like to know if there is a document or readme somewhere that describes this change in functionality?
If not, I'm interested in other ideas about what might cause the error when updating drivers.
Matt
04-10-2017 09:06 AM
Hi Matt,
The documentation is correct. I talked to some of my colleagues and we would love to see screenshots of what you have in NI MAX as well as what you're inputting into your control. Think you can attach them on here?
04-10-2017 09:37 AM
I've attached screen captures of NI-MAX, and two diagrams and their respective error outputs.
04-11-2017 09:33 AM
I'll troubleshoot on my end with those specific versions of the driver and OS on a virtual machine. What strikes me as odd is that the driver jump shouldn't have changed drastically. With the 'traditional DAQ' syntax, has it ever worked before?
04-11-2017 10:04 AM - edited 04-11-2017 10:08 AM
It has been working for more than 10 years. It is only with the upgrade to 15.1 or 16.0 that it stopped working.
I noticed that the NI-DMM versions aren't visible in the MAX screen capture I posted yesterday, so I've attached an updated screen capture.
04-11-2017 10:40 AM
Upgrade to 15.1 or 16.0? What was the last working version so I can replicate it on my end?
Sounds like a bug but I want to double check.
