I am trying to write a program which sends command strings (like VER or MODE) to a RS-232C device. The device should give an appropriate answer to this command. Unfortunally I get timeout errors when LabVIEW tries to read the serial port (until now I tested it with the "Serial Communication VI" from the Hardware In- and Output Examples). The serial port seems to be OK because I worked through the "Serial Communication STarting Point"-Tutorial and there was no fault. The cable which connects the two devices seems also to be OK. When I send the commands mentioned above to the device (with a terminal program) I get the correct answer. What can I else do to communicate with the device within Labview 6.1 for Linux?
Th
anks in advance,
Armin Herzer
