09-12-2014 07:14 AM
I am a new user. Actually, I want to control pulse generator (Quantum Composers 9000 series) with LabView. i have already downloaded its driver online and now facing this time out error 1073807339. The virtual USB COM port is visible in the MAX as well as device manager. At the moment, i could perform VISA WRITE command which tells the return count of the data entered. I am using simple VI fo initialzing it, configuring the channels and then closing the VI all using the available VI's for Quantum Composers.
Could there be some issues with the USB port drivers as well?
How to solve this problem and to start toubleshooing?
Kindly have a look at the attached images.
Thanks!
09-12-2014 07:45 AM
You are not allowing the instrument enough time to do whatever those subVIs are telling it to do.
09-12-2014 07:49 AM
So what could the remedy for it? some time delay?
09-12-2014 08:47 AM
09-12-2014 08:57 AM
Yes! now i see that the instrument hasnot been connected! it should be displaying there but only the usb com port3 is visible not the name of the instrument itself. Any suggestions?
09-12-2014 09:11 AM
09-12-2014 11:05 AM
If your instrument is connected to COM3, then use COM3 and run.
09-14-2014 10:45 AM
@dennis,
The cable is USB cable i am using is USB A to USB B type typically used for pulse genartors. The instrument name is not showing whenever i connect it with PC in device manager, only it shows COM3 as port. Should i re-install NI VISA and update it from there?
09-14-2014 10:46 AM
@crossrulz
It doesn't work with COM3 port
09-14-2014 11:30 AM
