06-02-2014 07:21 AM
I am currently working on the following project:
With an acquisition card (AFE4490) manufactured by TI (they don't broadcast labview source code , or the driver for use directly ), I should be able to process the values in real time in labview . The card is connected to the computer via a USB port, but the chip communicates using a SPI port.
To do this, they gave me the datasheet of this card and the main operation is to write the different registers in this card from labview . I have a sheet with 30 registers with addresses and corresponding reading and writing addresses.
For example, after the initialization of the card, the first operation is LED2STC , address 0x01 and address read / write 0x0017C0 .
The doc says that the chip has 32 bits , it uses the first 8 to write the address and uses the 24 other to write the reading and writing addresses.
So I wanted to know how it was possible to enter these registers in labview ?
Attached a sheet with the list of the registers.
Damien
06-02-2014 11:07 AM
06-03-2014 02:21 AM
Thank you for your reply but I'm in charge of this project over an unpaid formation, so I thought more programming ideas in labview directly. I saw a feature that allowed to write a 32-bit block, that is what I want, but I don't know how to wire it.
Damien
06-03-2014 03:12 AM
06-03-2014 03:17 AM
What do you mean?
06-03-2014 07:23 AM
06-03-2014 07:43 AM
The chip is integrated into the capture card and is connected to the computer via USB.
06-03-2014 10:42 AM
06-04-2014 02:54 AM - edited 06-04-2014 02:56 AM
Yes here is the datasheet, page 47 to 73 it explains how to read and write data, but there is no link with Labview...
There is a software that was installed with the card, but it does not meet expectations because it does not allow to take continuous measurements, unlike Labview.
I use Measurement and Automation software that allows me to see the TI card and access its properties and see its attributes.
06-04-2014 03:05 AM
