10-15-2014 01:35 PM
I have a high power voltage supply. I need to slowly ramp up the voltage of the power supply, say 20 V per second, up to 1000 V.
I can control the power of the supply manually. For example I can set the power supply to be 100 V run the program, then 120 V run the program, etc. Is there a way to have the program do this automatically?
Attached please see my code.
Thanks for the help.
Respectfully,
Andre
10-15-2014 01:56 PM
What power supply? Do you have drivers for it? A simple FOR loop or a state machine could easily do this.
10-15-2014 02:17 PM
I have a SRS PS 350.
Can I take my entire program and then do a small for loop with a let's say half a second delay? How would I incrementally increase the power to the supply?
Thanks for your help.
10-15-2014 03:30 PM
Use a shift register to hold your set voltage and increment it with each iteration.
10-15-2014 03:39 PM
10-15-2014 04:04 PM
10-15-2014 06:48 PM
Could you please provide me with a bit more information, where do I find the ramp function? and do I simply replace my manual control with a ramp function?
I apologize LabVIEW is not my strong area.
Help is greatly appreciated.
10-15-2014 07:42 PM
10-15-2014 09:38 PM
