01-14-2015 02:55 AM
How xy stage can be interfaced using labview software?
01-14-2015 06:28 AM
Which XY stage? Did you do a search for drivers? What are you trying to do with it?
01-14-2015 07:56 AM
This question should be asked in the LabVIEW forum with a lot more detail.
This is the wrong forum. This is only for asking for conversions of VI's between different LabVIEW versions.
01-14-2015 08:26 AM
I have already asked for this thread to be moved to the Instrumentation Control board. So you can go ahead an keep using this thread (no need to create a new one).
01-14-2015 11:24 PM
actually the problem is I want to do interfacing using labview to control the xy stage of stepper motor and want to detect its movement coordinate vise...like if start from (0,0) and move 30m in x direction then it shows (30,0)......
sir please guide me...
01-15-2015 04:09 PM
01-16-2015 12:15 AM
Dear sir, thank you for your kind reply.
I am working towards my final year undergraduate design project. I am facing difficulty while designing control panel using Labview for controlling stepper motor (that is placed below the XY STAGE i.e. for control movement in X and Y direction).
01-16-2015 12:48 AM
01-20-2015 12:35 AM
Respected sir,
I want to control the (x,y,z, theeta) stage through labview(3 similar stage: maximum movement 50mm*50mm, theeta~ 20 degree with resolution 0.1 micro metre)
As per requirement possible items:
- stepper motor(8 no.)
- DAQ card( suitable to control 3 similar stage using one DAQ card)
- any other item , if required please suggest.
please provide all possible option.
thanking you
01-20-2015 07:52 AM
@komalsoni201227 wrote:
Respected sir,
thanking you
I hope no one here is stupid enough to do YOUR work for no money.
