@komalsoni201227 wrote:
Respected sir,
I want to control the (x,y,z, theeta) stage through labview(3 similar stage: maximum movement 50mm*50mm, theeta~ 20 degree with resolution 0.1 micro metre)
As per requirement possible items:
- stepper motor(8 no.)
- DAQ card( suitable to control 3 similar stage using one DAQ card)
- any other item , if required please suggest.
please provide all possible option.
thanking you
If you really want help, you need to give a lot more information. What models of devices have you picked out? What are you exact specifications? What have you tried already? Where exactly are you stuck?
