06-26-2014 08:58 AM
Update:
Turns out to be a hardware issue.
We have two USB-serial cables. One has a Prolific chipset. The other has a different chipset.
The one with the Prolific chipset works fine.
The other doesn't. It's driver may not be quite compatible with Windows 8.1.
Though it worked fine with a different piece of equipment.
The cable with the Prolific chipset was recognized instantly in Windows 8.1
06-26-2014 09:19 AM
06-26-2014 09:23 AM - edited 06-26-2014 09:24 AM
Can you check the handshake lines?
Sometimes (when some galvanic isolation is involved) you need to 'power' the rs232 circuit in the device.
NEXT: REALLY check your cable!!
Do you have switched and or high power devices near ? (Oh yes, the stepper motor 😉 ) check your GND lines for a clean gnd line to the PC !!
EDIT ... too late 🙂
06-26-2014 09:28 AM
Also, a co-worker had another USB-serial cable with FTDI chipset. Needless to say this cable also worked fine.
