You can use GPIB to exchange data between to PCs. In this case, one of the GPIB interface has to be configured as a non-controller and execute a program that perform GPIB I/O based on the controller addressing commands.
This operation is described on this article:
Computer to Computer Communication via the GPIB. Also check
LabVIEW Always Sets GPIB Boards as System ControllersThe non-controller application acts as the firmaware used in embedded devices (Instrument using GPIB ports).
You would need to implement the whole communication protocol to determin
e how the terminal works.
Hope this helps.
DiegoF
