NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Active Participant
K C
Re: Serial com with USB485 - ModBUS
Hi Eric,
Maybe you can try to read an address and see what your slave returns.
The CRC calculation method is always the same.
Kees
Member
ethibault123
Hi Kees,
I decided to try with the MODBUS library from labview because i was becoming crazy trying to write my own cmd...
Good news... I can read and write SOME registers...
I don't understant why, if you look at the register table i sent to you recently, I can do what ever I want from the list from page 72 to 85 (what they seem to call legacy parameters table).
But whenever I try to do read/write another address higher then 760 (40761), i have an illegal address error code. Any idea why?
Example: If I try to read the address 44804 (4803 from labview) I got the error.
Slowly... getting through it...
Eric
Active Participant
K C
Hi Eric,
Had a long weekend. No computer no forums ... no NI
Now it is getting device specific. I see no reason why you cannot communicate with the mentioned addresses.
Kees
Member
ethibault123
Hi Kees,
Yes, long and hot weekend (here in Canada). Warn weather is finally coming up.
Ok well thx a lot for your help, it helped me a lot.
You are good :smileywink:
Bye,
Eric
Member
No_RegreTs
Could you please convert it to 2009SP1. I can't open 2011.
Yasemin Barutçu
Electrical And Electronics Engineer
Member
Courtney_L
Hi Yasemin,
Which file do you need converted?
Best,
Member
ethibault123
Hi
This one? Let me know if it works.
Eric
Member
No_RegreTs
Hello Courtney,
and Test2.vi would be great.
Yasemin Barutçu
Member
Courtney_L
Hey Yasemin,
These should do the trick.
Best,
Member
No_RegreTs
Thank you very much, they worked.
Yasemin Barutçu
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
