04-24-2013 01:26 PM
I had the same issue when using LabWindows CVI. Hooked up a scope to verify the Tx waveform. Exact same; Arduino Serial Monitor versus CVI. While idle, the Enable pin on the APC220 measured high, however, when the CVI program invoked the USB port via the VCP, the enable pin went low and remained low during byte transmission. I removed the enable pin from the APC220, and all is working, as the node is held up on it's resident PCB. I'd rather control the pin versus make a mechanical fix, but that will take some time to implement. Hope this helps.
07-18-2015 05:32 PM
HOLAS Q TAL POR FAVOR NO PUEDO CONECTARN APC220 (43) CON LABVIEW VISA
INTENTE POR TODOS LO MEDIOS ALGUIN ME PODRIA AYUDAR O DAR UN LINK DE QUIEN LO HAYA REALIZADO
POR FAVOR NECESITO UN EJEMPLO GRACIAS
