Serial RS232 directly to a USB DAQ?
I have a question regarding serial communication: is it possible to directly hook a device via RS232 serial to digital pins of a USB-6211 DAQ? (Or maybe even a USB-6008?)
If so, where should I wire the pins to?
If not, could you recommend me a not too expensive, yet functional RS232 to USB adapter which could work fine? (I am planning to interface a Datex capnometer or a Fresenius Pilot C infusion pump first, however if I could find a relatively well-priced multi-port adapter I would go on with both. BTW, can I include more NI-VISA queries in parallel in LabVIEW?)
__________________
Engage! using LV2015
(6,088 Views)
Accepted by topic author jeanlucpicard
No, you cannot use a daq device to simulate a serial port.
I don't have a specific recommendation for a vendor but I've had much better luck with adapters built with a chip from ftdi than from others. Google 'usb to serial adapter'.
You can have multiple communication threads with multiple adapters.
(6,084 Views)
Okay, then I should proceed with the adapters. With these I had a bit difficulty:  I find plenty of devices which support USB to UART RS232 (based on FT232RL and FT232RQ chips), however I guess, that these are not suitable for my needs. Am I right?
__________________
(6,070 Views)
No, you are not right. Why do you think the ftdi chips you mention are not suitable? What sort of 'difficulty' do you have?
(6,054 Views)
The main difficulty is that I am not familiar with these devices. I thought it was not suitable because all the pages say that cables based on these chips are for 3v3 to 5v connections between an arduino and a pc, while there are some more expensive cables which do not mention uart or 3v3 connection.
Should I worry about this or can I go on with these chips?
__________________
(6,048 Views)
If you buy a cable that says it is USB-RS232 compatible, then you are okay. The voltage levels of the chip itself is level shifted. Look at the specs for the assembly for compatibility.
(6,044 Views)
Okay, thanks 🙂
__________________
(6,041 Views)
