Hi, I'm having a hard time dealing with my serial port. When I send a command (for instance, 'Whello', which should display 'hello' on the instrument panel), it doesn't seem to actually send. If I send Whellowoiaydsociahncu4ynriausfaiu(insert at least 80 characters), the display will read "hellowoiayds" (the display is 12 characters wide).
So how in the world do I tell the COM port to send the command without requiring all 80 characters? Note that I can have it send "W1234567890" and press send 8 times, and the command will be sent on the 10th attempt. I assume the buffer is being filled as I send the short command, and only actually sends after it is full. If I don't send something to the buffer within 2 seconds, the buffer is cleared.
Is this a computer problem or programming thing? I've tried turning off FIFO, but it didn't help (maybe I have to reboot to make that setting work?)
Thanks for your help,
-James
