05-19-2017 03:01 AM
but when i try to do..i have also an error with the timeout.
05-19-2017 01:45 PM
Tagni,
Do you know how to use the Arduino IDE serial monitor? I would suggest you test any arduino code using that before you write any LabVIEW code. Basically once you get it working on the serial monitor you can adapt the code (by using some sort of handshaking so you know when a message starts and ends) in LabVIEW. As was suggested earlier using the println command and setting the termination character on the VISA Configure Serial Port.vi is one way to do this.
Read this page and try the attached code. Then read the arduino.cc page to see how you can adapt the code to more then 1 byte. Continue down that path until you can use the println command effectively.
05-28-2017 12:52 PM
Hi Everyone,
Software:Labview 2013
Hardware:Arduino UNO
Problem description:
i try to upload this LIFA-BASE and i get this one as error:
LIFA_Base.cpp.o: In function `loop':
C:\Program Files (x86)\Arduino/LIFA_Base.ino:59: undefined reference to `checkForCommand()'
C:\Program Files (x86)\Arduino/LIFA_Base.ino:65: undefined reference to `sampleContinously()'
LIFA_Base.cpp.o: In function `setup':
C:\Program Files (x86)\Arduino/LIFA_Base.ino:39: undefined reference to `syncLV()'
i attach also a Screenshot.
Could someone help me here?
05-30-2017 10:13 AM
If you insist on using a LabVIEW toolkit to help you with your project I suggest you read this. Your questions would probably get more visibility on the LINX site forums.
