07-17-2014 11:20 AM - edited 07-17-2014 11:24 AM
Hello, I'm trying to control the genesys TDK-Lambda 750W power supply through serial communication(Through hyperterminal). I have connected my power supply with the PC using a RS 232 cable with DB25 and Rj-45 connectors. THe power supplu has the following settings:
Bits per second:9600(Default)
Parity :None
Address:06(Default)
For serial communication the power supply is setted to use RS232 in the rear panel.
I have verified the address, the baud-rate, the switches on the rear of the instrument, but it appears all ok.
I have verified the COM in the PC, too..but it doesn't talk with the tdk lambda. when I send "ADR 06" to the power source through hyperterminal it should say "OK", but I read only
ADR 06
ADR 06
I don't know whether the communication port on the power supply is enabled or not.could any please help. Thank you
07-17-2014 11:41 AM
07-17-2014 12:30 PM
You are the one sitting in front of the instrument. How are we to know?
09-12-2014 03:57 PM
Baud rate needs to be set to 19200.
Have fun.
10-27-2014 07:30 AM
mraya001, were you able to get this to work? I have the same Lambda power supply with the Lambda-supplied RJ45 to DB9 RS-232 cable and I get no response from the power supply whatsoever, just a timeout.
The port on the supply is enabled as far, as I can tell from the documentation. The PC's serial port is functioning because I can use the NI-MAX VISA Test Panel to communicate with two other devices that are presently sitting on my desk.
Unless I missed it, the documentation does not say anything about having to send special termination characters, but it wouldn't surprize me if that's what it is.
10-27-2014 09:52 AM - edited 10-27-2014 09:53 AM
Ok, I got this to work using the VISA Test Panel in NI-MAX. It was the termination string which Dennis alluded to in a previous post.
Make sure you uncheck Send End On Writes. The power supply requires only a carriage return after a command. Nothing more, nothing less. Oddly, it will not work if you check Enable Termination Character. Once I unchecked those and manually added the \r to the end of my command strings, everything worked. Also note that the supply will not respond if it doesn't get a ADR\s06\r as the first command in a "session" (the \s and \r are just visual representatives of a space and a carriage return respectively. 06 is the factory default address setting).
(edited for spelling)
