Computer 0: System controller, primary address 0, PCI-GPIB.
Computer 1: Non-controller, primary address 1, GPIB-USB-B.
Both: Windows 98, driver version 2.0 after upgrading from original 1.7, otherwise defaults (no secondary address, timeout at 10 seconds, EOI on last byte but no EOS, bus timing 500 ns, no HS488, automatic serial polling is on). Each machine's MAX observes its own interface GPIB0 with no problems and local tests are passed.
Both: When using MAX to scan for instruments, scan cannot be done because each machine thinks that the other one is powered off or there is a cable problem or whatever. So it looks like a cable problem, but I don't think it is.
The blue box of the GPIB-USB-B can be plugged directly into the con
nector of the PCI-GPIB. It doesn't matter if I put a cable in between or not. Neither machine can detect the other. So I don't quit e believe it's a cable problem.
On the non-controller I turned off automatic serial polling (not sure if it means anything on a non-controller) but it made no difference.
On the non-controller, when trying to scan for instruments, the "activity" light flashes a bit. I wonder why non-controllers are allowed to try this operation, but fortunately this capability yielded this observation. When the controller tries to scan, the non-controller's activity light doesn't visibly flash. So I don't think the USB cable is damaged either.
The two computers example also fails, they can't detect each other on the bus.
Any ideas?
