04-17-2014 02:52 PM
When my program creates a report, I want to save it as a serial number defined in the report. I want to use the MS Office Report Express VI to do this but unfortunately it only allows you to save the file name as a time/date and/or incremental number.
Solved! Go to Solution.
04-17-2014 03:04 PM
04-18-2014 03:52 AM - edited 04-18-2014 03:53 AM
Hi jliu317,
While waiting for you to notify the moderator to move your thread, here is my solution. (Correct me if I'm wrong)
In MS Office Report, there is a block diagram input called Path to Save Report. So this is where you can save your report in Words (.doc) or Excel (.xls) with customized filename such as serial number, as shown below.
http://zone.ni.com/reference/en-XX/help/370274G-01/lvoffice/ms_office_report/
Hope this helps.
-Ee Lim-
04-18-2014 06:05 AM
Duplicate thread over in the LabVIEW board:http://forums.ni.com/t5/LabVIEW/Custom-file-name-when-saving/m-p/2820390
04-18-2014 07:16 AM
Thanks. I guess it only shows up when you tell the VI to specify file path. By the way what are those yellow icons you used?
