Safely Remove GPIB-USB-HS Devices
I have several GPIB instruments connected to PC through GPIB-USB-HS. I know normaly for USB devices I need to do the safe removal. What should I do in this case to remove connections while everything is powered on.
Fliu
(4,355 Views)
Accepted by topic author FLiu
I try to always power down an instrument before disconnecting it.
(4,331 Views)
Thank you for your reply.
(4,305 Views)
