08-21-2014 08:56 AM
Hi
can any one let me know how to send SCPI commands to an agilent device over USB itnerface, i installed USBTMC drivers and the device is listed out in the /dev/usbtmc0, now i have to send the SCPI commands to fetch the data.
A sample command example how to send the SCPI commands.
varun.p
08-21-2014 09:00 AM
Use the VISA interface as it doesn't really care what the actual bus is. From there, it is just writing and reading the strings.
08-21-2014 09:11 AM
Hi
Thanks for the reply, can you pleaseee bit explain more here i am very new to this device.
08-21-2014 09:22 AM - edited 08-21-2014 09:24 AM
@varunp wrote:
Hi
sounds like some LabVIEW tutorial is required
http://www.ni.com/academic/students/learn-labview/
Edit: the OP's post is a duplicate of http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/N6705B-connectivity-via-GPIB-interface-in-UNI...
08-21-2014 11:28 AM
09-21-2014 09:59 PM
09-22-2014 07:23 AM
@Vanir wrote:
There is an easier method than the path of despair and career suicide (Labview).
Career suicide?????
You really should stick your head out of your hole and see what the current job ads for test engineers require.
10-03-2014 07:45 PM
10-03-2014 11:35 PM
