SCPI commands
Hi
can any one let me know how to send SCPI commands to an agilent device over USB itnerface, i installed USBTMC drivers and the device is listed out in the /dev/usbtmc0,  now i have to send the SCPI commands to fetch the data.
A sample command example how to send the SCPI commands.
varun.p
Message 1 of 9
(7,134 Views)
Use the VISA interface as it doesn't really care what the actual bus is.  From there, it is just writing and reading the strings.
GCentral
Message 2 of 9
(7,133 Views)
Hi
Thanks for the reply, can you pleaseee bit explain more here i am very new to this device.
Message 3 of 9
(7,130 Views)
@varunp wrote:
Hi
sounds like some LabVIEW tutorial is required
http://www.ni.com/academic/students/learn-labview/
Edit: the OP's post is a duplicate of http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/N6705B-connectivity-via-GPIB-interface-in-UNI...
Message 4 of 9
(7,128 Views)
For detailed help, you need to say what programming language you are using. There are examples included when you install NI-VISA.
Message 5 of 9
(7,113 Views)
Your statement about any real company not using LabVIEW is just ridiculous. I'm sure you said that to just start a flame war. Please be a little professional.
Message 6 of 9
(6,923 Views)
@Vanir wrote:
There is an easier method than the path of despair and career suicide (Labview).
Career suicide?????
You really should stick your head out of your hole and see what the current job ads for test engineers require.
Message 7 of 9
(6,908 Views)
My guess is that you are bitter that no one would hire you. You really have nothing worthwhile to contribute.
Message 8 of 9
(6,793 Views)
I've reported you as a troll for your unprofessional and unwarranted comments.
Message 9 of 9
(6,798 Views)
