NI Home
Cart Cart | Help
You are here:
Reply
Trusted Enthusiast
Albert.Geven
Re: Rs-232 digital potentiometer using SPI and USB-6008
Hi
why can't it work?
and it seems you really are in a hurry after a few weeks silence
greetings from the Netherlands
Member
ankitsharma
[ Edited ]
i tried a lot,it can not change the value of resistence of digi pot mcp41010..can you give me the right programme...
Member
dalvares
Hi Albert, Sorry I think there is some confusion.:smileyhappy: Its another user who seems to be in a hurry after not myself.  I haven't had the chance to look back on it and it seems like I might not need it after all as I just purchased a couple of ICs that can better solve my problem.
Ankitsharma. I suggest using possibly the 7555 as your clock signal
Cheers,
Darren
Member
ankitsharma
can you briefly tell me,how can i use 7555 to generate the clock
Knight of NI
Perhaps you should consider actually looking at a datasheet?
Trusted Enthusiast
Albert.Geven
sorry Darren, did not look deep enough
Member
kamil8
hello
I know this is a fairly old post but I have a similar problem to control digital potentiometer with USB 6008 now. I also use SPI digpot
Did you succeed to change digital potentiometer resistance with USB 6008 using RS232? Can you give me clues about how can I do it? I don't quite understand with the attached files in this thread
I'm very stuck now
thank you
Member
kamil8
or did you just use arduino?
Member
Daniel-E
Hi kamil8,
To be clear, are you using LabVIEW, or another NI software product to communicate with the digital potentiometer, or is this a separate program using the DAQmx API?
I might suggest making a new thread for your question so that other forum responders can see that you have a new question and be more able to help you out, even if the question is similar (as you said, this is a fairly old thread).
Daniel E. || Applications Engineer || National Instruments
CTDCLD
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
