04-29-2005 06:28 AM
@Shawn B. wrote:
This doesn't really seem to be related to the question above, so it probably should have been posted in a new thread, but I can try to help you out anyway.
After you have run scan for instruments and your instrument is found, what does it say next to the Identification property in the middle when you select your instrument in the tree? Also does the Error LED appear when you open the Communicate with instrument dialog, or when you press the query or write buttons?
Have you checked your instruments manual to see what the Error LED means?
Shawn B.
04-29-2005 11:56 AM
