RS232
Respected Sir,
My name vijay mani, working as a researcher in bologna university,
i am working newly in the labview software.
while running lab view program, it is showing like
connection to the acquisition board was not found
continued with predefined values or stop program
I would kindly ask your help regarding what i should proceed further.
we are using National instruments microprocessor FP-1000 Field point RS-232/RS-485
Thanking You
Yours friendly
vij
(2,649 Views)
Hi Vijay,
could you better specify the error you are getting? You can post a screenshot of the error message.
Is the FP system detected in Measurement & Automation Explorer?
Does the error appear immediately after running the LabVIEW application or after a period of correct funcitionality?
What is the application doing? Is it acquiring data from some FP modules?
Just a note, since the issue is related to FP-1000, you should have posted in FieldPoint Family board.
Licia
(2,629 Views)
