RS232 framing error
Hi-everyone.
I am using optoNCDT 1401 as a displacement sensor, which give digital optput from 40 to 4055 with RS232 interface.
Bit rate: 38400 Data bits: 8
Parity: none; One Start/Stopbit
Line length: 10 m
but I am not able to get searial data properly.
some time it give framing error and it does not give framing output nver been in correct format.
I am attaching snap shot of my program and output without error.
thanks in advance.
gurkirt
IIT Kanpur
(5,968 Views)
Be sure the RS-232 settings are OK.
The Framing error source can be a bad connection, wrong RS-232 levels or defective hardware.
(5,963 Views)
Hi Gurkirt,
These links might help you..
http://digital.ni.com/public.nsf/allkb/F3E0621CB71AA16786256F970000FC57?OpenDocument
http://digital.ni.com/public.nsf/allkb/13A20C0F9DF265FB86256FC60066D9C2?OpenDocument
Rajshekar P
(5,921 Views)
Adding a low quality cable , noise / interfearence / groundloops to the cable, or the cable capacity is to high for the driver circuit at this speed. A scope at the PC-RX might give a hint.
Can you make a short connection directly to the unit?
Greetings from Germany
Henrik
LV since v3.1
(5,832 Views)
Hi Henrik,
Du hast so regt……(so far for my German writing)   Smiley Tongue
Too bad, there is no further reply from the originator.   Smiley Sad
Kees
(5,823 Views)
thank you all for replying..
rs232 cable and connection are fine i checked it with other software it works fine with other software but there is allways a problem with labview.
please have look at the snapshots i have attached.
thanks and regards
gurkirt
iit kanpur
(5,820 Views)
The snapshot only shows a read from the COM port. Can you post the complete program.
With the snapshot you set the com port parameters and read the com port once.
(5,810 Views)
