02-14-2007 10:14 AM
02-14-2007 11:19 PM - edited 02-14-2007 11:19 PM
Message Edited by PIPL on 02-15-2007 10:21 AM
12-14-2008 12:07 PM
Dear Friends,
I am new user Of NI LABVIEW 8.6 software and i need help in establishing a serial(RS232) comm with PC,presently I have been assigned a job to establish a communication between a Dynamic Torque measuring system ( Binsfeld Engg)output signal in to a PC Based data acquistion system. The System gives an output of + 10VDC corresponding to the torque present in the shaft , the output can be tapped either via two way connectorin form of voltage or directly via it's RS232 Port.The equipment manufacturer does not provides any driver software since they say it can be done easily in lab view.
Further The details as mentioned in the Equipment manufacturer manual is attached with this mail.
Pls help me.it's very urgent.
Waiting for reply.
Pls help me.
12-14-2008 12:21 PM
12-15-2008 10:07 AM
Hi ,
Welcome to NI community .
I went through the Spec Sheet which you gave but i did not get the company and model number .
Please try locating an instrument driver for the same at
www.ni.com/idnet first . If you cannot find an instrument driver there you could build one of your own from Instrument Driver Project which you can take through
templates .
The basic level of communciation can be done thorugh Visa Serial Read Write itself which you will find in the examples of LabVIEW
Please provide us with your inputs for the above users so that we can provide you with more information .
Thanks and Regards ,
Pranchal Srivastava
08-07-2011 02:16 PM - edited 08-07-2011 02:17 PM
I know the question a few posts up from Rahul was from several years ago, but I ran into this same application, reading the digital streaming data from a Binsfeld TT10K. Rahul's post was the only thing I could find on the web and it took me some time to figure it out, mainly the data decoding. Hopefully this will help someone in the future.
For reference:
The entire manual for the Binsfeld TT10K system is here:
The digital streaming protocol part from the manual is here
Attached is some example code written in LV 10 and also an image of the same code.
09-04-2015 07:38 AM - edited 09-04-2015 07:53 AM
Dear All,
Hello, i am new to LabView and practically dumb to this kind of high-level programming. I have the same problem as Rahul of about 4 years ago (trying to couple Binsfeld's TT10k to my PC using LV2013). I wish to use my TT10k ASAP for some torque-thrust measurements making this situation even more furstrating. The parameters of the device are somewhat known from previous posts. So, I would like to know if there is any step-by-step guide to create a driver for the TT10k, making it "readable" ("findable? ", "discoverable?") thus enabling me to use it with LV and finally recording some measurements?
I 'm in a difficult situation here, so any prompt and quick reply would be most appreciated.
Thanks in Advance!
